ArchLand.pngFitting walls to defined geometry
Command
Workspace: Path
Fit Walls to Objects
Architect: AEC
Landmark: Landmark > Architectural
In the Vectorworks Architect and Landmark products, standard walls and curtain walls can be set to the layer height at creation. After creation, they can be automatically extended upward or downward to fit to defining geometry such as the site model, roofs, floors, or NURBS surfaces. Selected walls are automatically associated with any roofs they intersect; see Roof and wall associations.
To fit walls to defined geometry:
Select the straight or curved walls to be fit.
With the walls selected, select the command.
The Fit Walls to Objects dialog box opens. Specify the location of the wall object and indicate the fit parameters.
Parameter
Description
Constrain tops of selected walls to objects
Fits walls to objects at the top of the walls
Fit to objects on
Specifies the layer of the defining geometry for the tops of the walls; this geometry can consist of roofs, floors, slabs, 3D polygons, extrusions, or NURBS surfaces
Wall top embedding depth
Specifies the distance that the wall penetrates the object. This can avoid problems such as gaps; for very thick walls, a negative embedding depth may be necessary so that the wall does not protrude from the object.
Constrain bottoms of selected walls to objects
Fits walls to object at the bottom of the walls
Fit to objects on
Select the layer of the defining geometry for the bottom of the walls
Include Site Models on selected layer
Conforms the bottom of the walls to the shape of the underlying site model
Curved wall fit interval
For curved walls, sets the increment for fitting the wall
Wall fitting reference
Select the part of the wall to fit to the constraining object (Center, Left, or Right)
Walls or portions of walls that lie outside the constraining object retain their height as set from the Object Info palette. Walls that have had peaks added (with the Reshape tool) do not have the peaks reset if the peaks lie outside the constraining object. Walls with a bottom fit to the site model retain a level top rather than a fixed height; the top of the wall does not vary with the bottom.
Creating walls
Deleting all wall peaks
Deleting individual wall peaks
